fan indicator light - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2008, 10:09 PM
CARGUY's Avatar
fan indicator light
what would be the best way to wire a indicator light to the electric fan to let me know the fan is actually on [i have it wired with a relay]
Old 11-17-2008, 10:33 PM
302 Z28's Avatar
The easiest way is to just use an illuminated switch, but that really will not tell you the fan is running, only that it's getting power. Unless the fan has some kind of feedback signal I don't know of any other way..
Vince
Old 11-18-2008, 09:32 AM
CustomConspiracy's Avatar
Indicator light
I am more of a Painter than an electrician but I kinda wanted the same thing you are looking for.
My guess is ya have to find the spot between the little control box that tells the fan what to do, and the actual fan motor. When juice travels from that relay to the fan .....the fan runs.
If ya stick a light in between the source of power, and the , motor then the light gets power when the fan does......I think?
The other question is......if you run it like that.....you may need to be careful that the light can handle all the load that is traveling thru it to get to the motor.
Now that you have read all that......you know why I am a painter and not an electrician.....LOL
Old 11-18-2008, 09:39 AM
302 Z28's Avatar
Sorry, but that will not work, any light you place into the power feed to the fan motor will reduce the power level to such the fan will not run. Short of having some direct information (running) feedback the only legitimate way to do it would be an illuminated (led) switch.
Vince
Old 11-18-2008, 10:26 AM
Wiki Edits: 31
wire it paralell to the fan from the relay to ground. you can't do it in series but paralell would be fine
Old 11-18-2008, 10:48 AM
Countilaw's Avatar
Cox Custom Cars
The easiest way to attach a light would be find the lead to the relay from the water sensor unit. The sensor is a grounding unit that supplies the ground to the fan relay. When the sensor attains the set temperature it closes. This works like a ground wire from the relay. When the sensor closes it will complete the coil circuit causing the relay to close turning on the fan.
If your run a positive wire to the light, then run the other pigtail (ground wire) to the lead going to the temperature sensor.
When the sensor supplies ground to the fan relay, it will also provide ground to the indicator light.
Frank
ID:	34265   Click image for larger version
Old 11-18-2008, 10:56 AM
Frisco's Avatar
Glad To Be Here
I ran an electric cooling fan full time when the ignition switch was turned on in the '28 Ford pickup that is my avatar.
To be sure that the fan had power running to it when the ignition switch was turned on; I wired in an "icecube" relay from Square D (I worked for them at the time). It was wired so that if the fuse going to the fan ever blew out, an indicator light would light up in the dash to alert me off the loss of power to the fan. That relay and its mounting base are still available from electrical supply business.
Old 11-18-2008, 01:39 PM
lg1969's Avatar
Google "Tunnel Ram 406"
I happen to be a eng. tech. I did that when the fuse blow open the light would come on. Just connect a small 12V bulb across the fuse. The same bulb used on the dash. You will need an insulated socket.
Old 11-18-2008, 05:48 PM
You could try this wiring scheme, but leave out the yellow light (green lights up when fan is on).
Bruce
http://www.classictruckshop.com/club...osch/relay.htm
building a fan shroud - need help 32Tudor Hotrodding Basics 30 07-03-2008 10:01 PM
Correct size & type of radiator fan & clutch? Steve S Engine 3 12-04-2006 11:29 AM
Electric cooling fan Z-Money Pit Engine 1 08-29-2006 09:27 PM
Need advice on a good electric fan set up. Streetmaster Engine 13 01-07-2006 03:37 PM
? about an electric fan for PU. Streetmaster Engine 8 08-20-2005 11:14 PM
