Fan issues on 97 camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2010, 09:54 AM
McSS86's Avatar
Hello I have a little problem with my fan on my 97 camaro when the temperature gauge gets on the 1/2 mark the fan remains off but when it reaches 3/4 of the temp gauge it turns on and drops back to the 1/2 mark and the fan shuts off again and it constantly does that what may be the solution to this problem? But now when i keep the car idling in park it goes all the way to the red and it starts to smoke a lil.
Old 02-13-2010, 10:04 AM
ericnova72's Avatar
More for Less Racer
That is how it is supposed to work, it has a fan control thermostat that only turns the fan on when it is needed, turns it on at high temp, shuts it off at normal temp. The fan does not run all the time.
Old 02-14-2010, 10:25 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Also, the fan switching and the gauge may run off different senders*, and one, (or both), may be slightly out of calibration.
* I'm not sure on that particular year...
Old 02-17-2010, 07:02 AM
rick your right the gauges and the fan are on seperate sensors on the buick motor but not the LS , the fan should turn on at idle at the same temp as it does in drive , if you over heat the car once it usually smokes the sensor for the fan , you can have the ecm programmed to lower the turn on point , what motor you have 6 or LS ? if its a ls you should have someone run a dia on the ecm .
Old 02-21-2010, 12:33 AM
fast68's Avatar
likes chevy trucks & boobies
CTS may be acting up, if anythign at all
or its just normal cycling
if its not overheating then i dont think there is anything bad happening..
97 F150 ABS issues fast68 Suspension - Brakes - Steering 7 02-08-2010 06:34 PM
building a fan shroud - need help 32Tudor Hotrodding Basics 30 07-03-2008 09:01 PM
Clutch Fan malibuman66 Engine 18 01-01-2005 10:09 AM
elect fan help 96 camaro kiaserknife Engine 0 11-10-2003 05:02 PM
86 iroc camaro electric fan dougbev3 Electrical 5 10-06-2003 08:07 PM
