fan rubs on shroud - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2004, 01:14 AM
montea's Avatar
tryn to learn
fan rubs on shroud
the engine fan scraps on the fan shroud on my 82 grand prix. where do i adjust it so it doesnt do it? i tried loosening the fan shroud/cover and pulling it back and tightening it back up and still rubs.
guess i could cut the shroud a bit underneath, but i would want that to be my last option
Old 08-12-2004, 10:39 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
H'mmm
Try slotting the bolt holes so you can move the shroud a bit..that may help..
Old 08-12-2004, 11:08 PM
Pony's Avatar
If it didn't rub before and just started to rub, check for a broken motor mount. It will allow the motor rock under acceleration and cause the fan to rub.
Old 08-12-2004, 11:32 PM
montea's Avatar
tryn to learn
thanks for the replys... i think il try and slot the bolt holes like OneMoreTime says. i had my whole front end off my car and when i put it back on i had the rubbibg probs.
Old 08-12-2004, 11:50 PM
Wiki Edits: 3
R&R Sheet metal
That is a good clue to the issue as it is likely that the sheet metal did not quite go back just exactly the way it came off..not to worry as it happens to all of us at one time or another..Doesn't take much to cuas a rub here or there..
Check the motor mounts while yoy are out in the garage if ya haven't done so as tha tis alos a good possiblity..
Old 08-20-2004, 11:12 PM
nicowarrenrogers's Avatar
That happened to me on my 1969 mustang. All i had to do was losen the radiator and sit on it than tighten it again. Just my expirience with it
Old 08-20-2004, 11:20 PM
montea's Avatar
tryn to learn
i took the top bolts out and took my dremal to the shroud and made the holes longer and put the bolts in and pulled back on the shroud and tighten them up and its perfect now. wahoo
Old 08-22-2004, 07:49 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
Did you check your motor mounts just to make sure they are fine too?
Old 08-22-2004, 08:12 PM
montea's Avatar
tryn to learn
how do i check the motor mounts? i should of replaced them when i had my whole front end off and the engine out... o well to late now
Old 08-23-2004, 08:25 PM
Ghetto Jet's Avatar
have someone hold their foot on the brake and put the car in gear while you look at the motor, if the motor is moving more than it should be then you probably have a broken mount.
