Fan Shroud for '65 BBC Impala SS - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2005, 09:28 AM
Camarofiend73's Avatar
I've got a question on fan shroud size. I'm helping a friend search for a fan shroud for his 1965 SS 396 Impala w/A-C. I found one on E-bay, but the description lists it as a "small block fan shroud", I thought that they were basically the same size and just the depth varied. Any information would be appreciated.
Old 10-05-2005, 10:29 AM
66Caprice's Avatar
Move It On Over!
The main thing is to get a shroud that will be the same width and height of the radiator and that the mount holes line up. Unless the person needs a stock OEM shroud, there are a lot of possibilities. I ended up getting a plastic shroud fit for a 66 BB chevelle because it was the same width and height as my radiator, but the mount holes didn't line up so I drilled new ones.
Old 10-05-2005, 10:45 AM
Thanks for the info 66Caprice- my buddy's car is a restored big block car and I'm not sure if the radiator is larger by the L & W. I'll have to get some dimensions from the seller on Ebay.
Homemade Fan Shroud? JohnTN Engine 4 07-18-2005 05:08 PM
Aluminum Rad or Home made fan shroud? sandiegopaul Engine 18 06-14-2005 02:10 PM
electric fan - no shroud? Blob Engine 11 02-09-2005 08:29 PM
Clutch Fan malibuman66 Engine 18 01-01-2005 10:09 AM
Radiator fan shroud Charles F. Smith Engine 5 10-02-2003 07:40 PM
