Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - fan shroud flex fan and water wetter for valiant
Old 09-03-2009, 12:50 AM
elcaminodragster's Avatar
elcaminodragster elcaminodragster is offline
70 El Camino aka FRANKENSTEIN
its a new radiator with a 180* thermostat. im not so sure its lean as it is a bit rich at idle and part throttle.
i will mess with timing and even the carb a bit. i did not drive enough after i got off the freeway to notice a drop in temps.
i realize 220 is not a "bad" temp but its a bit high for my taste. i would at least like to see the temps drop 15* even 10* would be nice.
