Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - fan shroud flex fan and water wetter for valiant
Old 09-05-2009, 12:48 PM
elcaminodragster's Avatar
elcaminodragster elcaminodragster is offline
70 El Camino aka FRANKENSTEIN
the balancer cant slip it has a key way on it. and it will take the advance but if i rev it up to say around 3000 it pops through the carb. the book says it should be timed at 0* TDC (with factory parts). i put in a 252H from comp cams. and they said to try advancing 2* at a time. 3* runs the best but its hurting the temps.
