Fan Shroud Size - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2002, 07:33 AM
Dave E Shank's Avatar
Post Fan Shroud Size
I am making a metal fan shroud for an aluminum radiator. Does the shroud have to be 360 degrees to be effective?? What is best material to use??
Old 12-03-2002, 07:18 PM
BOBCRMAN@aol.com's Avatar
Post
yes a shroud has to direct all the available air through the radiator, thats how the japs cool their engines with a radiator the size of a heater core. as for material use whatever you can work with that will hold up to the heat. i try to cruise the bone yards and get factory composit ones that i can modify, and make look good, but steel or aluminum.or certain plastics all make good pieces.
