fans not kicking on
i have a 1995 lt1 camaro and i have changed the temp sending unit and all fan control fuses and my heater also does not get hot even if the car is at a temp of 220 degrees why are my fans not kicking on and why is my heater not getting hot . if i set at a red light the car will beging to over heat and i have to turn the airconditioner on to make the fans kick on . someone please help
Sounds like a bad thermostat.
Sounds like you have a bad thermostat.
Have you checked your fan relays. Some cars use a 2 speed fan. The computer will call for low speed first, then if the car continues to over-heat the computer will call for the hi speed. The A/C always gets hi speed. Check for 2 fan relays under the hood.
