Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fans not kicking in 'til 237* on a 218* switch
Old 04-27-2008, 02:05 PM
curtis73's Avatar
curtis73 curtis73 is offline
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Depending on sensor locations, coolant temps can vary up to 30 degrees throughout different places. Often times there is a 10-15 degree difference between the manifold and the heads.
I wouldn't worry about the shrouding of the sensor. Water is an excellent conductor of heat, plus there is plenty of turbulence around that fitting. Plus, the fitting is probably brass and its almost as good as the water at conducting heat.
