? on a FAST efi fuel pump # 30085 inlet fitting - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2013, 09:03 PM
I have a used FAST #30085 inline EFI fuel pump. The inlet side of the pump accepts a 5/8 male straight thread with an o-ring( I think) and has a barbed 5/16" at the other end. I'd like to go to a larger inlet but I can't find much info anywhere about 5/8 staight threads with a o-ring much less where to get one. Any ideas?
Old 04-05-2013, 10:34 AM
S10xGN's Avatar
Gotta love a turbo!
Also known as an AN -10 male fitting, which are out there in numerous configurations. Try Speedway, Summit, or Jegs...
Russ
Old 04-05-2013, 09:46 PM
Ok, thanks I'll check into it. I have not dealt with those kind of fittings yet.
what fuel pump would you run? e85, efi, etc darkostoj Engine 9 03-07-2011 12:39 PM
No fuel to carb, do have fuel at pump inlet - replace? bruceg Engine 8 04-22-2010 09:41 PM
Dual Inlet Fuel Pump: One inlet capped ???? Sin7 Engine 8 07-29-2008 03:32 PM
EFI fuel pump oldred General Rodding Tech 20 09-14-2006 04:37 PM
efi fuel line sizing / fuel pump Blob Engine 2 09-25-2005 01:25 PM
