We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 09-16-2004, 11:08 PM
chris oswalt chris oswalt is offline
a fast formula HELP!
my bro couldnt get on so he is on mine. hey i have a 79 firebird formula with a 350 chevy dished pistons(cast) 76 cc truck heads, performer rpm (air gap) and a small but barly noticeable cam. th350 tranny and stock gears. the original motor was a olds 403cid. i am in the process of putting a performer rpm cam and my brothers fuelie heads, and some 373s from his friend. how fast in the quarter mile do you think i will be, will i go faster than the olds did ( being big block) it runs good and will pull away from his black 89 camaro vary fast (305cid tbi) and he has 273s or somthing like that. how fast will i be in the quarter? and what else do i need?
Old 09-17-2004, 02:56 AM
GoneNova/406's Avatar
GoneNova/406 GoneNova/406 is offline
if you're going to use those heads i'd have them cut down as close to 70 cc's as possible or just get on ebay or some of those used parts for sale sites,and there are many so take your time and find a better set of heads.you didn't say what size the valves are in yours but you most likely need to lower your compression.
everyone seems to think the vortec heads are the hot ticket these days because of price but i'll have to say i think in the long run you can do better.i bought a set of iron bowties 2 yrs. ago and had 2.05 valves put in before they were sent to me for less than $850.00 and i am very happy with them and the'll last forever having alot of extra material in the for porting.
so if you do some work to your heads or get new ones and start with a good electical system like MSD,carburation,intake asyou mentioned,headers and exaust and finally cam you should be set to hit the 12-13 sec. range.the rpm or torker cam should be good for a light car like yours.
you want about 180 lbs. of cylinder pres. if you can get it.i've used 350 head gaskets as opposed to a shim on my 406 in the past to help with this.good luck.
p.s. remember to use quality parts beause the time spent down and the money spent twice is just harder and more expensive.also you're going to need a tork converter.about 2800 stall.tci,coan,j.w. perf.trans,b&m,hughes,buaman,art carr,
its important not to go cheap here.go online with a converter company and describe your set-up and give them your cam srecs. and they will get you the right converter.i exspect it will be around 2800.
Old 09-17-2004, 11:22 AM
Siggy_Freud's Avatar
Siggy_Freud Siggy_Freud is offline
Siggy_Freud's barnstar
Wiki editor
Gonenova has given you a good start.
Just for reference sake keep in mine the 89 TBI camaro had a whopping 170 hp. So hopefully when your done your going to absolutely scream by that thing.
1997 BMW M3 - 3.2litre Inline 6 cylinder
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
