VWFAN, he simply used a throttle cable and ran it to the lever that the inside handle actuator rod hooks to. That is all there is to it. That cable ran out the front of the door thru a hole and then thru a hole in the door jamb and then thru a hole into and out of the cowl side under the fender. You stuck your hand in behind the wheel under the fender and grabed the knob on the end and pulled, pop, the door opened.
