-   -   Fast Xfi setup info ? (http://www.hotrodders.com/forum/fast-xfi-setup-info-87239.html)
x007 04-18-2006 12:58 PM
Hi,
Ok i'm in way of finishing the install on my XFI and need some Help...
Using :
- Ati custom build Damper whit Crank Trigger build in.
- MSD EFI sync Distributor PN 2340.
- Running XFI whit Sequential setup.
First i have managed to put the pickup on the Crank Trigger at 60 BTDC (i know should be 50 but it was not possible to put the pickup at 50 deg whit the bracket i have so i will use 60, should work no prob if i set this in the software).
Now i want to know how to setup the Distributor(cam sensor), The MSD PN2340 is set at 45 BTDC on cyl. 1, if i'm right i should have the cam sensor at 70 to 190 btdc right ?
And how to set this the correct way ? Somewhere i read to set the engine at peek torque ex: 30 deg. on timing tab then set the rotor to point to cyl. 1.
But i also read to let it at 60deg. then setup this way...
I'm lost...
thanks for any help.
If there some Xpert of the Xfi outhere !
