Fast Xfi setup info ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2006, 12:58 PM
x007's Avatar
Supercharged T/A
Hi,
Ok i'm in way of finishing the install on my XFI and need some Help...
Using :
- Ati custom build Damper whit Crank Trigger build in.
- MSD EFI sync Distributor PN 2340.
- Running XFI whit Sequential setup.
First i have managed to put the pickup on the Crank Trigger at 60 BTDC (i know should be 50 but it was not possible to put the pickup at 50 deg whit the bracket i have so i will use 60, should work no prob if i set this in the software).
Now i want to know how to setup the Distributor(cam sensor), The MSD PN2340 is set at 45 BTDC on cyl. 1, if i'm right i should have the cam sensor at 70 to 190 btdc right ?
And how to set this the correct way ? Somewhere i read to set the engine at peek torque ex: 30 deg. on timing tab then set the rotor to point to cyl. 1.
But i also read to let it at 60deg. then setup this way...
I'm lost...
thanks for any help.
If there some Xpert of the Xfi outhere !
-= Build for Power =-
Creating NEW t-bucket frame plans - Need TONS of info, plans & measurements - HELP! lowROLLERchevy Hotrodding Basics 121 08-30-2011 06:31 AM
How to setup gm rear end dpjim2 Transmission - Rearend 3 02-08-2006 08:43 AM
Need info Holley/supercharger 950cfm HP - Race Series ? x007 Engine 7 09-05-2005 10:58 AM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
400 SBC Balancing and info ? Brobob Engine 8 10-31-2002 03:44 PM
