fastburn385 crate or mod my 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2005, 07:36 PM
Bandit1980's Avatar
Hi ,I'm want a small block chevy with around 400 hp at the flywheel. I was looking to find a good set-up for my 350 but I found a FastBurn 385 350CI/385HP with Aluminum Vortec Heads on www.gmpartsdepot.com
What do you think is the best:
-the FastBurn 385 350CI/385HP with Aluminum Vortec Heads
Or
-What could be a nice set-up for my engine .not sure how my engine have hp but I think it's a targetmaster crate engine with around 180hp ( 3970010 , 350ci)
Or
-Is it better to buy a new block or a partial build engine and completly built a new engine
Old 02-05-2005, 07:46 PM
rick458's Avatar
Wookie
Probably be cheaper to build up your present Motor
buy the heads, Cam intake and Carb
as opposed to a $4400.00 crate motor
or you could throw down another $500.00
and get this bruiser
http://www.gmpartsdepot.com/product1...&Category_ID=2
Rich
77 Impala
74 260Z (a Work in SLOW Progress)
69 Big Block Chevelle (long gone)
Semper Fi My Brothers
Old 02-05-2005, 08:50 PM
Bandit1980's Avatar
yes the 383/425 seam to be a great powerful engine but don't have waterpump ,intake ,distributor so it's not 500$ more . But anyway what cam carb and head do you suggest for my actual engine ?
Old 02-05-2005, 10:27 PM
rick458's Avatar
Wookie
first off what vehicle is it going in IE What does it weigh, what trans and what rear end ratio are you running, and will it be a daily driver?
The Vortec heads are very good for Iron heads, $270 a piece
Air flow Research 180CC are great for aluminum but $1100 ish
for the pair.
the Cam will be very dependant on the gearing and use
but a Comp 268H or a 270M would probably work
and a 600-650 cfm Carb
best bet is call Comp Cams, Crane, Isky, etc.. and give them
what you have and what you want to do with it, they will steer you right.
Use a Edelbrock Performer RPM intake decent low end pretty good top end
Rich
77 Impala
Old 02-06-2005, 01:16 AM
Bandit1980's Avatar
Thanks .A trans am 1980 with a th350 and a 3.73 posi . I want to drive it all day and keep my stock torq for the moment.What do you think about roller rocker. And how do you think I can increase hp whith this set-up without changing bore piston and crank. sorry I don't know my actual compression ratio
Old 02-06-2005, 02:38 AM
Bandit1980's Avatar
Hi . When I see the intake section of the edelbrock web site ,I also saw
'' Building a Bowtie 420 HP Package and dyno test results for the 7101 power package.''
on the section of performer rpm . I think this conversion coud be great. But with a 750 speed demon in remplacement of the edelbrock. I'm not sure of the price but what do you think of this build
Old 02-06-2005, 03:16 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
perf rpm package
The performer rpm package is a great package for the novice builder. It gives you the basic parts and combination to achieve a certain goal.
If you just start mixing and matching parts without knowing what you are doing. You will end up spending money for parts that don't work with other parts. I see it in these forums everyday.
Old 02-06-2005, 11:56 AM
Bandit1980's Avatar
Tnanks Bracketeer . Do you know others great packages for a 350ci for around 400hp?
Old 02-06-2005, 12:02 PM
JUST my 2 cents.........
Buy the crate engine.......then you will have a warranty and well matched parts. You can buy a 430 HP 350 ( ZZ430 clones ) for 5 grand........they haul bum bum and idle decent......great sleeper motor.
I have a original General Motors built ZZ430 in my 32 and it is very well mannered, gets decent mileage and FLYS.........in my 2200 pound Roadster.
Old 02-06-2005, 02:50 PM
Bandit1980's Avatar
I found info about zz430 http://www.sallee-chevrolet.com/Chev...eeZZ430HP.html
What is the price and can I buy it another place than salee-chevrolet ?
Old 02-06-2005, 09:28 PM
302 Z28's Avatar
I believe Pace Performance also has it. You can also buy the Fastburn and some places will upgrade the Fastburn with the optional camshaf and springs. This will raise the HP from 385 to 430.
Vince
Old 02-06-2005, 11:05 PM
rick458's Avatar
Wookie
The Big GMPP dealers are
Pace
Scoggin Dickey
Smiley
Friendly, and
Sallee
http://www.sdpc2000.com/catalog/1578...rip-Engine.htm
Rich
77 Impala
Old 02-07-2005, 02:34 AM
bracketeer's Avatar
489 Lemans
$5000 seems alot to pay
Junkyard core $200
SRP forged pistons $350
http://www.jegs.com/cgi-bin/ncommerc...fnbr=4643&prmenbr=361
Eagle forged Rods $266
http://www.jegs.com/cgi-bin/ncommerc...fnbr=1241&prmenbr=361
Edelbrock 64 cc heads $1160
http://www.jegs.com/cgi-bin/ncommerc...fnbr=1249&prmenbr=361
Edelbrock perf/rpm roller rpm cam $220
http://www.jegs.com/cgi-bin/ncommerc...fnbr=3780&prmenbr=361
My last machining bill $1200
(you will not get this carried away)
boil out block, magnaflux crank and block, turn crank .010-.010, line hone main caps, bore .030, parallel deck, torque plate hone, preassembly for rod clearance, tear down, and balance rotating assembly.
Oil pump $35
Cloyes Timing Chain $48
Gasket set $75
Bearings $69
Tss Gapless Rings $145
http://www.jegs.com/cgi-bin/ncommerc...fnbr=4470&prmenbr=361
Total $3768
With money left over we can buy
Edelbrock perf/rpm airgap intake $310
http://www.jegs.com/cgi-bin/ncommerc...fnbr=199617&prmenbr=361
Holley 650 $340
http://www.jegs.com/cgi-bin/ncommerc...fnbr=756&prmenbr=361
Mallory HEI distributor $95
http://www.jegs.com/cgi-bin/ncommerc...fnbr=266037&prmenbr=361
Holley Blue Electric Fuel pump $106
http://www.jegs.com/cgi-bin/ncommerc...fnbr=1497&prmenbr=361
Total $4619
$381 left for wires, oil, antifreeze, etc
Old 02-07-2005, 07:13 PM
acr acr is offline
There is an outfit in Dallas, Texas called AUTOCENTER that sells GM crate & custom built motors. They have a 320HP+ long block motor that they build using all new parts, GM block, Edelbrock aluminum heads, etc. for $2395. They have a 400HP option that is $2595, & other HP options in between. You can also buy a two year warranty for about $400.00. As far as their reputation goes I know nothing about them. You can check them out at www.goautocenter.com
Old 02-13-2005, 01:03 AM
Bandit1980's Avatar
Do you think this engine could be a nice Start up base http://www.gmpartsdepot.com/store/pr...Category_ID=63
350/290hp 4 bolts but not forged crank
-I would like to put this summit 2X4 intake SUM-CWND303
http://store.summitracing.com/defaul...=egnsearch.asp
-performance head and cam, probably edelbrock
-Roller rockers
-Do you think stock fuel pump could be ok (is it better with a electric pump)
What do you think about this set-up .I want to have more than 350 hp
