Fasteners ... 18.8 Stainless or Grade 8 ?
Hi,
I've ordered and received a whole bunch of 18.8 stainless-steel bolds, nuts, and washers in a few of the popular sizes. Most of the chassis hardware that I have removed has a Grade 8 headmark on it, and now I'm having second thoughts on using the stainless to replace them. I've been told that the 18.8 specification is a pretty good grade of steel, but then again ... I've had someone tell me that stainless galls up the threads really easy when you tighten it ... indicating to me that it's too soft? I'd really like to use the stainless, for both it's anti-corrosive and appearance properties. Painted bolts are OK I guess ... apperance wise ... but we all know that wrenches/sockets don't fit right and that it chips off when you try to assemble it, right? The other possibility might be to use all new cadmium-plated grade 8. Can anyone attest to the anti-rust properties of the cad-plated fasteners? |
18-8, aka 304, nominally has 18% chrome and 8% nickel. While it's ultimate tensile stress is fairly high, it's yield strength is fairly low (70K and 30K if memory serves). It will gall unless you you anti-sieze on the threads. Even then it is suspect.
I would limit it's use to cosmetic, low stress environments. Stick with cad plated grade 8 hardware for you suspension and chassis if you have a driver. When the cad plating starts to deteriorate, replace them. |
| Stainless Steel Parts Inquiry | Dane Faden | Engine | 6 | 05-10-2007 09:08 AM |
| Questions about stainless steel brake lines | ckucia | Suspension - Brakes - Steering | 14 | 06-13-2005 07:26 AM |
| Will this hole punch work on stainless? | Dave Carney | Garage - Tools | 15 | 02-04-2005 12:35 AM |
| Reparing Stainless Trim.. How? | bigfred1958 | Body - Exterior | 3 | 11-05-2004 08:52 PM |
| Stainless hairpins | Mrfixmaster | Suspension - Brakes - Steering | 1 | 06-13-2004 10:15 AM |
