Fat fender Ford steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2006, 06:45 PM
Has anyone used a manual steering gear other than the original Ford or Vega. I have split wishbone and drop axle with stock gear that steers hard. I was wondering if some later manual gear would have better ratio that would make it turn easier.
Old 01-19-2006, 04:45 AM
Years ago, I used a Saginaw box from a 69 Olds Cutlass. Three of the 4 mounting holes fit the Old Ford frame and the pitman arm was the same length and correct vertical distance/angle. I may have done something with the hole in the arm that received the tierod end but can not remember. This box is almost like power steering in comparison to the original Ford box!!
Trees
Old 01-19-2006, 08:59 AM
32 Ford Model B
Last journal entry: 32 Ford LittleTruck Family History Pt 10
My father-in-law also installed a Saginaw unit in our 32 Ford truck. Having not driven it yet, I can't vouch for it, but it is generally recommended for larger heavier cars over the lighter Vega unit, so it may be a good choice for you.
Old 01-19-2006, 05:15 PM
The hunt is on.
A big thanks for the info. A friend that is into that type of car says all GM " G " body should be the same except maybe the pitman arm. Once more, Thanks.
Ford Truck Steering woes Kaylah Suspension - Brakes - Steering 4 08-15-2008 05:09 PM
steering column for 34 ford coupe jaxhome Suspension - Brakes - Steering 2 09-12-2005 06:59 PM
`37 Ford hard steering ? Rick 5150 69 Suspension - Brakes - Steering 4 06-06-2004 05:31 PM
34 ford steering column vette66guy Suspension - Brakes - Steering 3 06-01-2003 07:04 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
