Favorite Street Converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2005, 10:20 AM
68NovaSS's Avatar
Wiki Edits: 9
I don't know how to do a poll so I'll just ask outright.
What converter have you guys used for the street, I've got a blown 383, I won't lay out all the specs needed for a recommendation here, just curious about different brands and how they performed. I'm looking for something in the 3200 to 3600 rpm range, mostly street use at 'around town' speeds in front of a T-400.
I got a recommendation from TCI but that guy was bizaar, recommended a 10" 4600 stall.
Thanks, Larry
Old 03-19-2005, 10:45 AM
S10xGN's Avatar
Gotta love a turbo!
I've got a Precision Industries Vigilante 9.5" single disc LU with a #6 pump (3400 stall) in my truck and it behaves like a stocker until you nail it. My engine is a low RPM (6200 rev limiter) turbo motor which builds some awesome low-end torque, so your setup should be similar.
My only *complaint* if you'd call it that, is the shift light (5600) stays on continuously when you nail it! It only drops 800 revs between shifts, so I'm thinking I could run better with a tighter converter.
Russ
Old 03-20-2005, 10:28 AM
I build my own converters at my trans shop. Tailored to the individual customer. All stall speeds and configurations available.
Help is only a PM away.
Old 03-20-2005, 11:12 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
convertors
I have a B&M 2800 holeshot. Had it taken apart. New heavy duty stator and anti-balooning plates installed.
Old 03-20-2005, 01:42 PM
jakeshoe's Avatar
After a LESS than satisfactory experience with BTE converter, I'll be buying elsewhere next time...
TCI Stall Converter - Blown SB 68NovaSS Transmission - Rearend 10 09-09-2008 12:42 PM
TH350 gap between converter and flexplate QUESTION chrisgarrison Transmission - Rearend 6 12-26-2004 11:32 PM
stall converter adam15425 Engine 26 10-15-2004 05:50 PM
what does lockup mean 67bird Transmission - Rearend 31 02-25-2004 10:21 PM
possible bad toque converter? Deadtemple Transmission - Rearend 9 10-11-2003 06:53 PM
