Fb 396...How much hp ?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2012, 03:29 PM
Man!!..You Guys Are Great!!!...Thanx again for all of your info!! I live in a 'poor' neighboorhood. I Have No Access to a Dynomometer. I don't think anybody over here even knows what the word means. Can any of you tell me ('best-guess') about How Much Hp/torque This Thing Will Make? This Is It...stock-bore '67 396 2-bolt Main Block (from A '67 Chevelle SS, 4-speed), Stock Pistons (w/small 'dome'), Crank/rods Stock, '72-'74 454 Heads With 2.19/1.88 Valves (were 2.06/1.72), Weiand 'Stealth' Intake, .566/.566 Hyd. Cam, 1.7 stamped steel Roller-tip 'cheepo' Rockers, Holley 750 'dbbl-pumper' Carb, Summit HEI, 'cheepo' Headers, Electric Fuel Pump,....I Think Thats It. I'm guessing 425-450hp Is this close?.....Thanx Fellas..
Old 06-12-2012, 11:45 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Hard to tell unless you post the head casting numbers, but you're being very optimistic.
First of all, pre-1972 engines were rated at gross HP. By today's standards, a 400-hp engine now makes about 300 hp.
Secondly, swapping to the later heads dropped your compression significantly. We also have no way of knowing what cam specs you have. The lift numbers tell us very little. Do you know the duration?
My honest guess with what you've posted is no more than 350 hp.
Old 06-13-2012, 05:38 PM
fb 396...thanx Curtis
325-350hp...maybe? Hey I'll take it Man!!..(For right now)!! I checked the Duration is .236. Lobe separation is 110. ......Dammit!!!!... I forgot to get the cyl head P/N!! But I got them off Ebay couple years ago. They're off of a '73 Suburban. ..thanx
Rare 396/375 or just another 396? LilHerm Engine 4 06-11-2012 11:43 PM
396 Alan Byers Engine 19 09-21-2007 04:40 PM
Is it a 396/350 or a 396/375 hollywoodbob Engine 12 07-30-2003 10:51 AM
396 Again sboston Hotrodders' Lounge 4 04-24-2003 06:03 AM
396 sboston Hotrodders' Lounge 3 04-23-2003 04:17 PM
