Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - FE block code
Thread: FE block code
Old 06-27-2008, 12:41 PM
oldbogie oldbogie is offline
Originally Posted by Shelby1
As usual every time I try to remember something off the top of my head I screw it up .Oldbogie is right The 360/390/410 all had the same bore (4.05) they changed the stroke to change the displacement .410 had a 428 crank (3.98 stroke) and was a Mercury-only available in 1966-67. But to go back to my first post you never know what you will find when you open a FE block up because so many parts of these engines will interchange the person or engine remanufacture's that build them would use what ever they had on hand to build another motor to shove out the door to make another buck.
Later
Kenny
I hear ya, I'm only up on FEs 'cause I'm helping a friend with his 427 Cobra, original not kit, one wicked piece of machinery.
Bogie
