Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - FE blocks
Thread: FE blocks
Old 03-05-2005, 01:27 PM
Max Keith's Avatar
Max Keith Max Keith is offline
FE Block goodies
One thing to note on using a 410/428 crank. They are externally balanced vs the rest of the FE blocks which are internally balanced, so this will require a 410/428 flywheel, Unless you plan to have the entire assembly rebalanced.
The 406 has the same stroke as the 390 and 427, Im assuming that was a typing error there.
