FE Motor Mounts (pic) - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2003, 06:33 PM
BigBlockBabe's Avatar
Missing You
Post FE Motor Mounts (pic)
I'm sure KULTULZ will know this...
I got these 390FE motor mounts, but I yanked them outta the box without thinking. Now I don't know which one is for the right side and the left side.
They look exactly the same to me, 'cept for that lil bump near the stud. I've been told they ARE different. And if it matters they're being modified to work with the 429.
<a href="http://www.superford.org/registry/vehicles/showpic.php?pID=38748" target="_blank">Here's the pic..clicky.</a>
Thanks!
Old 02-14-2003, 09:17 PM
Missing You
Post
Oh come awn!
You boys disappoint me.
Old 02-15-2003, 03:29 AM
aka Duke of URL
Red face
I seem to have an ongoing problem with disappointing women...
It has been so long that I am not sure which is which. If no one else here is sure, I would suggest you take them back to the parts house and match them up. But if you will be fabricating frame/engine brackets...I doubt that L or R will make much of a difference.
...sigh...
Old 02-19-2003, 05:03 PM
New Member
Post
If ya can wait a day or so Ill try to clean the snow around my 66 Ford wagon with a 352 and see if I can see anything... Same block, right? if they were BB chevy it would be easy one hole on top 2 on bottom...
Old 02-19-2003, 07:02 PM
onebadmerc's Avatar
I need a bucket of arc sparks
Post
Your in luck I just swapped out my 352 in my 1967 F250 to a 390 Monday and Tuesday. The mounts go with the bump facing downward and the metal tangs to the back.
Old 02-19-2003, 07:17 PM
Missing You
Post
Sweet! Thanks.
Kinda figured that's how they went.
Old 02-20-2003, 06:50 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Babe; Is your BB an FE? I don't recall your in-progress pictures looking like an FE, but then I am not a Ford expert by any means.
Old 02-20-2003, 09:16 AM
Missing You
Post
No, its not. My BB is a 429. The FE motor mounts can be modified by enlarging the bolt hole and turning them to work on the 385 series engine (429/460.)
I've been telling my dad about using FE motor mounts for two years, back when we began this project. He never believed me and argued that they wouldn't work. So then he goes to the junkyard for some other stuff and the guy is like "yeah, modify some FE mounts."
My dad comes home all confident like what I was telling him all along was his idea.
Old 02-20-2003, 09:19 AM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
Post
Men.
Old 02-20-2003, 04:55 PM
New Member
Post
Dads
