FE question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2012, 07:25 PM
Last journal entry: 1964 Mercury Marauder as raced in NASCAR
FE question
Hi All, Does anyone know if the fuel filter canister is being reproduced for the 406 and 427 FE engines? Or where to find a good used one. Thanks.
Old 03-16-2012, 09:52 PM
I am much more familiar with the FE engine being in pickups, I have a 1966 F250 with a 410, built from the original 352, with the help of a 428 crankshaft, and a 1974 F250 Super cab, with a 390.
The 1966 came with a canister type fuel filter on the bottom of the stock fuel pump.
When I replaced the fuel pump on the 1974, I asked for the 1966 fuel pump to get the canister type fuel pump.
Old 03-17-2012, 07:14 AM
FE question reply to reply
Hi, the fuel filter canister that you are thinking of is the kind that screws on to the fuel pump. Those can be bought new from many vendors. The one I need is a complete canister with a top with the fuel inlet and outlet set up to accept the 3/8" inverted flaired fittings and houses the filter element. Thanks for responding though.
700R4 Corvette Servo question, (pin question) Guntar13 Transmission - Rearend 3 11-10-2011 12:05 AM
sbc timing question and carb question.....i am ready to absorb your knowledge c_cham Engine 16 02-12-2011 11:26 AM
steering question and brake booster question Hwyhogg Suspension - Brakes - Steering 0 11-21-2010 05:02 PM
Timing question and cylinder head question.. Blackhauk90 Engine 3 05-22-2007 01:10 PM
not a rod question but an engine swap question for a daily driver.. DeathByGreaser Hotrodders' Lounge 2 01-22-2004 10:59 PM
