featherfill with a 1.8 tip? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2009, 08:43 AM
Last journal entry: Body work
I would like to use feather fill on my project but the largest tip I have is a 1.8.
I have a devilbiss hvlp and also an older devilbiss JGA 502 with a pressure pot. I'm sure the hvlp won't work but what about the pressure gun? I really don't want to buy another gun just to spray this but if I can get one cheap enough I will consider it.
Thanks.
Ed
Old 06-25-2009, 10:55 AM
Can you reduce it a little bit? Check the p sheet. It probably won't build as much reduced, but you can just shoot an extra coat.
I had to overreduce slick sand to shoot through a 2.0 tip. Otherwise, it shot dry, dry, dry.
Old 06-25-2009, 07:47 PM
You should be fine with the 1.8 tip.
What size tip for shooting jambs? cab Body - Exterior 1 01-15-2007 09:50 PM
Tip of the day number ? MARTINSR Body - Exterior 18 12-07-2006 01:14 PM
Tip of the day #24 MARTINSR Body - Exterior 32 04-12-2006 10:22 PM
Polished up my exhaust tip Malibucdl Garage - Tools 2 03-14-2006 10:56 AM
Gun tip size VWFan Body - Exterior 9 03-22-2005 12:29 PM
