feathing filler - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2007, 12:07 AM
feathing filler
so do I feather bondo with 80? or just get it close and move to 180 or 220 for the feathering? what size scratch do you want to spray epoxy over and then high build so it doesnt shrink back?
Thanks
Old 08-16-2007, 07:53 AM
You want to finish the sanding of the filler and any feathering of paint to be in 180. You want the finest scratches possible and 180 is plenty fine enough for most any epoxy or urethane primer to fill with ease.
Old 08-16-2007, 11:24 AM
Thanks, I should have better luck feathing now.
Plastic filler tips. MARTINSR Body - Exterior 14 03-03-2009 05:11 PM
The most common mistakes made by the newbe working with plastic filler. MARTINSR Body - Exterior 7 02-14-2006 10:21 PM
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 12:22 AM
sandpaper... 38 special Body - Exterior 14 10-11-2005 04:30 PM
