Feedback on engine mount design - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2009, 10:26 AM
Last journal entry: Better late than never
So I am mocking up engine mounts and would appreciate input from those with experience of such matters.
The engine is a 292 Y block, going into a '29 Highboy. The engine will be a mild build, more cruising than driving hard. The car is old school, not rat rod.
I am trying to put together mounts that blend well but provide adequate support.
Any input appreciated.
Oh, and I find it stunning that software that not long ago would have cost thousands is now available free, allowing 3D modeling like this! I can pan around the model from any angle like a walk-around. Really allows you to visualize the mounts before picking up metal.
Thanks,
Paul
ID:	36011   Click image for larger version
ID:	36012   Click image for larger version
Old 01-31-2009, 10:36 AM
I should add that I have both 3/16th and 1/4 steel plate and unless there is a specific reason not had planned to use the 1/4 inch. Hopefully this isn't total overkill?
Old 01-31-2009, 09:10 PM
Updated design. The engine sits too low between the rails to allow the former design.
ID:	36028   Click image for larger version
Old 02-01-2009, 11:54 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
you fixed the only thing i seen that had posibile improvement and that was box the end of the bottom
looks nice and the top looks better - cleaner
A Semi-untraditional engine design... Blazin72 Hotrodders' Lounge 1 04-28-2008 10:33 AM
Old 50's type Corvette engine mount. Will it hold? Holdenowner Engine 1 08-29-2006 07:16 AM
Crosley Engine Design For AA/FD BillyShope Hotrodders' Lounge 3 10-03-2005 01:01 PM
327 question adam15425 Engine 80 10-13-2004 10:22 PM
New Engine Built & Dyno'd babe_n_indy Engine 69 09-09-2004 08:26 PM
