Feel pretty stupid with this mustang II question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2005, 08:28 PM
jaxhome's Avatar
I pulled all the control arms and springs off my mustang II front end to sand and paint. Initially I kept the left side parts and the right side separate. During painting they got all mixed. First question-Is there a difference in the left or right side for the upper control arms, lower control arms or springs? There doesn't seem to be any L or R printed on them. Question 2- On the Upper control arm the rod that runs through the bushings has a curve in the center. I figured they should match the curve at the top of the cross member where the shock comes through. The problem is that one of them with the curve as described places the "grabbing slots" on the top, which of course doesn't make sense. No I didn't install the bushings and rod. They're new on this car that I bought. The frame is currently separate from the car. When I tried to put one side back together the coil spring didn't seem to sit correctly on the lower control arm. Plus, it appears that the upper control arm binds on the top of the backing of the spindle. I feel pretty foolish asking these questions, but my buddy and I are both baffled. Help!!!!!!!
Old 04-02-2005, 08:45 PM
advanced design's Avatar
Just havin' fun.....
Last journal entry: Wheels and tires
Help!!!!!!!
There shouldn't be a difference on the upper arms and springs left or right. The lower arms would only have a left or right if you have already installed the strut rod. The "grabbing slots" being on top would seem to indicate the control arm shaft has been installed 180 degrees from where it should be. In other words it should be swapped end for end within the control arm. Then when the curve of the shaft matches the top hat the "grabbing slots will be down. You will have to press out at least one bushing and turn the shaft around.
Old 04-02-2005, 09:04 PM
jaxhome's Avatar
Thanks
That helps with the control arm shaft. I'll get that pressed out tomorrow. Would you advise that I put the strut arms on last? Why would having them on in advance determine left from right , unless you mean if they point forward or backwards. The base of the spring doesn't sit all the way into the pocket on the lower control arm. Will that change when I put the car back on the frame?
Old 04-02-2005, 10:19 PM
Yes, the strut rods (if you have them) point to the rear. Additional weight on the suspension will flatten out the lower control arm which should permit the spring to seat better in the lower control arm pocket. If it doesn't there may be some other problem and in that case a picture would help.
I'd probably install the strut rods after the lower arms were installed.
Hopefully you won't scratch the paint while pressing the bushing.
Good luck.
Old 04-03-2005, 06:51 AM
Just a reminder (as if anyone needs one), we keep a metal stamping kit handy to our work benches so we can stamp parts like L and R or T and B so we can make sure they go back the way they came off. Sometimes many months go by between disassembly and reassembly and those little stamp marks are invaluable. Also, the US auto industry has been pretty good in marking parts if they differ. They are also pretty good about not doing any more marking than necessary so many times they will mark for one side only and the unmarked part will go on the opposite side.
Trees
Info on the Mustang and a general question... SkyMan9600 Hotrodders' Lounge 15 02-28-2005 05:33 PM
Mustang II front end QUESTION??? testlightST Introduce Yourself 2 12-30-2004 10:31 AM
Are Mustang II Crossmembers Safe? Jon Suspension - Brakes - Steering 14 10-17-2003 12:43 PM
Mustang II BigChevMan Suspension - Brakes - Steering 5 07-04-2003 01:18 PM
Welding a Mustang II Maverick Suspension - Brakes - Steering 2 06-19-2002 02:37 AM
