Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fel Pro 1003 Head Gasket Coolant Hole
Old 01-19-2013, 06:20 AM
hcompton's Avatar
hcompton hcompton is online now
Old & Furious
Grease helps also use some strong magnets on the block around the area your drilling so if any metal come away from the bit its grabbed by the magnets and may help hold any shaving under the block in place.
Most will come out the top. The shop vac works. Just hold it right up to the bit while you drill.
