Fel Pro 1003 Head Gasket Coolant Hole - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2013, 08:44 PM
I assembled my 327 and installed it in car. Not started yet. Long story but I pulled the heads and am installing new Fel pro 1003 head gaskets. Instructions say to drill a 7/16" hole in block between center cylinder exhaust valves if hole is not in block. Mine doesn't have holes. I've done some research and it seems almost universally recommended. My problem is engine is assembled and in car. How can I drill these holes now without loading the coolant passages with metal shavings? There is no way I want to pull the engine and take it apart. I was thinking I could drill it and vacuum most of the shavings before I break through and then use one of those antenna deals with the magnet on the end to reach down the hole to collect the rest of the metal shavings. I don't have any other ideas. Is this hole really necessary? The block has the two smaller holes to either side of where the new hole would be drilled. This is a street car. Any suggestions? Thanks.
Old 01-18-2013, 11:22 PM
68NovaSS's Avatar
Wiki Edits: 9
Heavy grease around the drill bit traps shavings too.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
Old 01-19-2013, 06:20 AM
Old & Furious
Grease helps also use some strong magnets on the block around the area your drilling so if any metal come away from the bit its grabbed by the magnets and may help hold any shaving under the block in place.
Most will come out the top. The shop vac works. Just hold it right up to the bit while you drill.
Old 01-19-2013, 06:30 AM
Is your 327 engine hi-performance, have aftermarket heads? The fel-pro Q1003 head gasket is a hi performance gasket. The hole is in the gasket because of the two exhaust valves that are side by side in the center of the head. This area puts out the most heat. Line the gasket up on the head to see if it has a hole drilled. If not the two smaller holes will provide coolant for this section. The stock factory replacement gaskets do not have these holes. If you want to drill the holes, tape up the cylinder bores and put some heavy grease on the deck and drill bit while drilling holes. If you have a shop vac have someone hold the hose to catch excess shavings. Nothing to it!
Old 01-19-2013, 07:40 AM
bondo's Avatar
Ayuh,.... Protect it as best ya can, usin' grease, 'n a shopvac...
If ya loose a few bits of iron down the hole, Don't worry 'bout it....
It's the coolin' jacket, not an oil passage...
'ell,... Us boaters pump all kindsa crud through the coolin' system, everyday, all day long...
It most all comes out, when we drain the block for winter, No problem...
At worst, it'll lay in the bottom of the coolin' jacket, 'n rust away...
Old 01-19-2013, 08:20 AM
Thans guys. Your comments are reassuring. I will drill the holes and just be careful to catch as much of the shavings as I can.
Fel pro - 1094 steel shim head gasket. monzter Engine 5 06-12-2012 08:14 AM
Fel-Pro 501SD Head Gasket Compressed Thickness ? Silver Surfer Engine 1 02-16-2011 10:50 AM
Fel-pro head gasket punch outs awoodman Engine 6 08-05-2009 09:43 PM
Some beginner questions about the Fel-Pro FPP-1003 Fishgrinder Engine 1 07-17-2007 01:53 AM
Will a fel-pro steel shim work as a head gasket? batman09 Engine 3 12-28-2004 09:35 PM
