Fel pro - 1094 steel shim head gasket. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2012, 07:02 PM
How do you guys install these, dry or with somekind of sealant on them ?
Engine is sbc with aluminum heads.
Best regards.
Old 06-11-2012, 07:38 PM
BOBCRMAN@aol.com's Avatar
I have used cheap-o aluminum paint on both sides for over forty years.. Install wet and check torque after a few heat cycles..No failures. But, I wouldn't use them with aluminum heads. They will Brinnel the surface of aluminum heads..
Old 06-12-2012, 06:01 AM
Hello Bob. This particular gasket is rubber coated, that's why i'm wondering if it should be installed dry or not
http://www.summitracing.com/parts/FEL-1094/
Best regards.
Old 06-12-2012, 07:25 AM
I wondered why I didn't recognize the part no.. I haven't used that particular gasket.. Because of the coating. Install dry.
Old 06-12-2012, 08:11 AM
DoubleVision's Avatar
I hope the heads are new, or if they're used I hope they've been milled. Real thin head gaskets are great for a tiny compression ratio gain and at getting the quench distance set correct, but they are unforgiving if the surface is slightly warped. As if it is, you'll be removing the heads again in short order.
This is why the standard fel pro and other gaskets are .041 thickness, they compensate for warpness up to .002.
Old 06-12-2012, 08:14 AM
How fast is fast enough?
Those are always installed dry on clean surfaces. Some people run away from them with aluminum heads and other use them with no problems. I've used them with iron heads with no problems. I may use them with aluminum heads in the future.
Fel-Pro 501SD Head Gasket Compressed Thickness ? Silver Surfer Engine 1 02-16-2011 10:50 AM
Fel-pro head gasket punch outs awoodman Engine 6 08-05-2009 09:43 PM
Head gasket, steel shim, needs any goo? Augusto Engine 6 06-25-2009 09:25 PM
Will a fel-pro steel shim work as a head gasket? batman09 Engine 3 12-28-2004 09:35 PM
steel shim head gasket stfinney Engine 5 11-08-2002 07:39 PM
