Fel-Pro or generic gasket to attach heads to headers? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2013, 06:28 PM
andrewakessler's Avatar
I purchased a Fel-Pro gasket set for my sbc. The gaskets to attach the heads to the headers seem to be of high quality, but come in three pieces (image attached)
I also purchased some shorty headers that came with a gasket specific to the headers. This gasket seems to be more fibrous than the Fel-Pro version.
Which style would work best: the three piece Fel-Pro, or the generic header gasket specific to the headers?
Also, I noticed there is a threaded exhaust port on the vortec heads. What is this for and is it OK to seal it with a plug?
Thanks,
-A
ID:	75513   Click image for larger version
ID:	75514   Click image for larger version
Old 07-09-2013, 06:32 PM
Circled opening should be water [for temp sensor , etc] should be threaded.... use the gaskts that came w/ your headers , I've good luck w/ the hi-temp copper silicone sealer on both sides of the gskt.
dave
The Following User Says Thank You to 2old2fast For This Useful Post:
andrewakessler (07-09-2013)
Old 07-09-2013, 06:38 PM
It is threaded. Thanks for the help.
-A
Fel Pro 1003 Head Gasket Coolant Hole Dougie Engine 5 01-19-2013 08:20 AM
Mr Gasket or Fel Pro? ComradeNorgren Engine 4 06-10-2011 03:02 PM
Fel-pro head gasket punch outs awoodman Engine 6 08-05-2009 09:43 PM
Will a fel-pro steel shim work as a head gasket? batman09 Engine 3 12-28-2004 09:35 PM
Fel-Pro Gasket DTL504 Engine 6 06-17-2004 08:31 AM
