Nope, they are made that way for a reason. The small hole provides somewhat of a pressurized means of coolant flow into the heads. Lots of things can cause overheating from vacuum leaks, lean mixtures, low spark timing, no spark advance, etc. And sometimes it takes alot of digging to figure it out.
my sbc 350 runs at 220 with a 180 thermostat always has due to lack of front grill. it shouldnt hurt anything, if it starts getting near 250 then you should worry
they are fel-pro 7733pt2 gaskets. And thanks knightrider. Is this the correct gasket for my application? I built the engine last year, dont remember exactly how i chose these ones. I have a rebuilt 350 with between 9.5 and 10:1 compression ratio. bored .030 over, hyperutectic pistons, iron heads: EQ lightning-CC180BA. 2.02/1.60 valves, around .500 lift int/exh cam, ect. edelbrock rpm intake, holley 670 street avenger carb. I hope you guys can help out, thanks again
you have the same engine setup i do except my heads are stock. my head gaskets have the large coolent passages and came with metal inserts that i could put in to narrow coolent flow. i left them out. i dont see have making the passages larger would cause overheating if anything it should help your engine run cooler. besides thats less work for your water pump and u migth free up 1/10 of a horse power!!!
| Head Gasket 101 | camaro freak | Engine | 9 | 08-06-2007 09:39 AM |
| Choosing correct Head Gasket - HELP! | NovaHO | Engine | 4 | 05-30-2007 06:39 AM |
| Head Gasket or Piston Rings? | 94dangerranger | Engine | 7 | 03-24-2007 01:33 PM |
| Cracked Head or Blown Gasket? | '71 rag top | Engine | 1 | 12-15-2004 10:08 PM |
| Suggested Head Gasket? | strikingthematch | Engine | 9 | 12-07-2004 05:36 AM |
