Why do you have to read in to some thing more than what it clearly recomends.
Clean dry, and oil free is what is recomended. This is what I have always used and have never had a failure even at 12.65:1 compression ratio. clean the block and head decks with lacquer thinner. New GMPP head bolts are recomended. torque to spec in 3 steps Retorque after engine break in. The new GMPP head bolts with a smaller head bolt size allow you to retorque the head bolts after break in without removing any of the rocker arms. use a small amount of RTV gasket sealer on the head bolt threads and under the head bolts. Nothing else is required. Leave all the other glup and gunk in the tool box. Any kind of "sealer" between the head, gasket and block acts as a lubricant, allowing the head and gasket to float on the block. This causes head gasket failure. The head and gasket must grip the block and not move to stay sealed. CLEAN DRY and OIL FREE |
More info HERE if you really want to know..... |
An excellent head gasket spray is sold by Chrysler. The local dealer will have it. Excellent stff.
Follow the recommendations from Fel Pro. They make the damn things. |
For the 1094 head gasket to seal the head and deck surfaces must be flat. Make sure that at least the heads are milled so that at least one surface is known to be flat. Heads that are new are not necessarily flat.
tom |
Cheers, Ian. |
| Engine Install Parts List | joeford | Engine | 0 | 09-05-2007 07:52 PM |
| How to install a chimney for a wood heater | rusttorod | Garage - Tools | 31 | 11-06-2006 08:56 PM |
| Spindle interchanges | bskaggs | Suspension - Brakes - Steering | 11 | 06-05-2006 01:29 PM |
| Question about .015 head gaskets - FelPro 1094 | surfshark | Engine | 2 | 03-30-2006 04:08 PM |
| *****in' Floorpan Install | 35WINDOW | Interior | 2 | 12-10-2005 10:03 AM |
