If you would be more specific on the motor you have, I could be more specfific on the gasket, but here are 4 different part numbers for Chevy inline sixes, all have 0.041" compressed thickness
http://www.summitracing.com/search/P...rd=head+gasket Here are 5 different part numbers for Ford inline sixes, they vary from 0.038" to 0.039" compressed thickness http://www.summitracing.com/search/P...rd=head+gasket |
ford 200 inline six. the gasket i pulled off has a
.045 compressed thickness. 3.8 gasket bore. the engine is a 3.68 bore. 3.126 stroke. 58cc combustion chambers. .010 deck height. ported polished head with unshrouded valves. crank turned for cleanup. the pis tons are -8cc. yielding 8:1 compression ratio depending on the thinnest gasket i find i can bump it up to 9.0 with a .038- .039 gasket and milling .035 off the head to achieve a 53 cc combustion chamber. |
yes yes techinspector u are very correct i have researched all over the interent trying different calculator even doing my own math and the compression ratio i stated was static not dynamic. dynamic as the engine stand without shaving the heads getting a special gasket or changing pistons i have a 6.35;1 DOES ANYONE HAVE ANY TRICKS they can lend a hand with me.
BTw i was entering in the piston volume in a negative number hence being a dome, when i have a positive meaning adding volume bc its a dish, WHat compression ratio is good for a supercharger and/or turbo application? and what cam should i install. |
I have a lil question to ask about lobe centers. doesnt a tighter lobe center cause the static compression to raise ,meanwhile a 112* bleeds off the pressure. or am i misinformed i read a thread on here about this i was just wondering on what i could do with this motor to make it perorm well wit a supercharger. in fact an M-90 to be exact. and a 2 brrl holley.
The term "lobe center" is sometimes used interchangably with the terms "lobe separation angle" or "lobe displacement angle". It describes the number of degrees separating the max lift points of the intake and exhaust lobes (intake centerline and exhaust centerline). LSA is determined when a camshaft is ground and cannot be changed by the end user of the camshaft. A tighter LSA (smaller number) results in a narrower and peakier torque curve, while a wider LSA (bigger number) produces a broader torque curve. The intake centerline can be adjusted in relation to crank and piston position when the cam is installed by the end user and can have the effect of increasing off-idle torque (advancing) or increasing peak RPM (retarding). You must realize though, that all four cam timing functions (IO,IC,EO,EC) change when you alter the relationship of the cam to the crank/piston. When advancing the cam, the intake and exhaust valve will open sooner and close sooner. When retarding the cam, the intake and exhaust valve will open later and close later. Quote:
| Head gasket compatibility | Greg T | Engine | 28 | 05-06-2010 11:50 AM |
| Help! Piece of Gasket Fell Into Intake... | lead09 | Engine | 11 | 08-18-2006 08:07 AM |
| Compressed gasket thickness | Rhansen | Engine | 2 | 11-20-2005 01:57 PM |
| Felpro head gasket specs | 8843astro | Engine | 0 | 05-19-2004 11:02 AM |
| Proper Gasket thickness available | 84stepside | Engine | 1 | 04-18-2004 07:16 PM |
