Fender exit headers - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2013, 08:00 AM
Fender exit headers
I made some fender exit header,well thay are almost finished.
Old 04-13-2013, 08:51 AM
RWENUTS's Avatar
Awesome!!
But I gotta ask!
Why??
Old 04-13-2013, 08:55 AM
vinniekq2's Avatar
not sure if there is a question in your post,but hey,,,nice.The last time I saw really nice custom headers was a 63 valiant with a 427 chevy. Steering clearance was an issue.
Old 04-13-2013, 09:12 AM
just a build
no question yet.The steering is an issue with #7 pipe but the welder is going to do his best to get around that but I am close to it.I just tacked the pipes together.
Old 04-13-2013, 09:19 AM
The hard part is the slip tube and the collectors getting them all tacked up.
Old 04-13-2013, 09:31 AM
The real pain is the passenger side exit,this is tubes 8/6 but I can't get them to turn and clear the wheel.
Old 04-13-2013, 10:48 AM
Great job so far. I seen lot of header projects started and never get as far as you have and they looked really bad. Post more pics wehen you're done.
Old 04-13-2013, 11:17 AM
Originally Posted by RWENUTS View Post
Awesome!!
But I gotta ask!
Why??
I am going to be making mor hp[1200]and I needed bigger headers than the 2" hookers I had and I am very tired of the headers crowding the starter,burning the trans blanket...These pipes are 2.250 and my old headers are 22yrs old.
http://www.hotrodders.com/gallery/sh...ls-pla/cat/500
Old 04-13-2013, 11:42 AM
RWENUTS's Avatar
Ah! I see!!
Too bad a set of tri Y's like schumacher has didn't come in a bigger tube size.
Your Car looks familiar.
Saw it on a video somewhere! Bangshift maybe.
Old 04-13-2013, 12:27 PM
vinniekq2's Avatar
when you get into higher HP figures,the tube length can be shortened
Old 04-13-2013, 01:06 PM
shorten length
I wanted to make equal length on my 1st try making headers and I have enough to do a set of zoomies as a back up plan.My tubes are 28" on the driver side coming into the wheel well.I tried an exh calc on wallaceracing and got 31.8" length I should use.I have to add the collector into the length so I will be close.
Old 04-13-2013, 01:59 PM
dr side mockup
here is the dr side mockup.
Old 04-13-2013, 06:07 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You plan to move that brake line on the passenger side? A lot of heat coming off the headers.
Semper Fi
Old 04-13-2013, 06:16 PM
brake line
I am replumbing it all and I have ceramic cloth for around the MC.I will inclose the brake line also idf need be.
Old 04-13-2013, 09:14 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Those look nice, very similar to headers Camaroman7 had custom made for his pro street Skylark from Lemons, with some of the tubes wrapped around the frame rail, a work of art.
Semper Fi
Building Headers, Exhaust port exit angle question mkloter Engine 1 06-15-2009 11:44 PM
inner fenders and fenderwell exit headers bullheimer Body - Exterior 0 07-23-2007 11:08 AM
SBC fenderwell exit headers bct Engine 1 10-30-2005 06:53 PM
where to buy fenderwell exit headers? newchevyman Engine 1 10-01-2003 06:26 PM
This is my cue to EXIT stonedchihuahua Hotrodders' Lounge 27 08-26-2003 10:09 PM
