fender fix (Really Bad) Help! - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2006, 06:28 PM
I have a fender that is eaten away with rust on the edges at the cowl side. There's a few holes also but I would like to round the edge with 3/16th rod or 1/8 either way you get the picture because at the end of my fender it's eaten away and I want to keep it looking like original if possible and I'm thinking it will give it some strength! Should I try and weld as much of any open space thats possible,(with other pieces of fender) and then start to use fiberglass repair and then the bondo stuff? OR am I way out of whack? Advise, Dana
Old 11-01-2006, 06:37 PM
Rambo_The_Dog's Avatar
Last journal entry: Shop Remodel Progress
Anyway you can post a picture of the fender and area of concern? It'd help in making a recommendation...
Old 11-01-2006, 06:52 PM
car builder
1. Never use any filler on holes or rust.
2. cut as much rust out as you can.
3. weld the new metal in place.(do not warp)
4. after all welding is completed grind the weld down.
5. use a very thin coat of bondo to smooth imperfections.
6. sand the bondo and use high build primer.
7. sand the primer smooth.
Old 11-02-2006, 06:43 PM
Thanks for the direction, here goes!
"Bowed" deck lid cruzinTLT Body - Exterior 3 03-04-2005 09:24 PM
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 09:20 AM
another useless post about myself. the bad got good the good went bad bullheimer Hotrodders' Lounge 6 09-29-2004 06:57 AM
My Report: ITS BAD. VERY BAD. Native Gearhead Transmission - Rearend 12 09-21-2004 10:30 AM
need advice bad! 400 small block irocan Engine 0 02-10-2002 04:17 AM
