Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fender patch panel cutting?
Old 01-18-2010, 10:36 AM
kevs79 kevs79 is offline
Originally Posted by red65mustang
what car is it?
my eye sight is poor but from what I can see is:
"if" patching with old steel is the only option then use panel bond adhesive...
welding on worn out (no strength left) steel,,,you end up with goobs of filler to hide all the warping and the welding heat depletes any corrosion resistance left in the old steel...
It is on a '79 Camaro. That is actually not the picture of the fender I am using, the metal is in good shape.
I was worried about warping.
