Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fender patch panel cutting?
Old 01-18-2010, 04:17 PM
kevs79 kevs79 is offline
Just thinking out loud here. It would be easier to make one cut and one weld accross the top, but then I run the risk of loosing the contour of the fender. I guess I could make the cut, then mount the fender back up before welding(top and bottom portions). Make sure it lines up w/the door by ok and then weld? Does that make sense?
