Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fender patch panel cutting?
Old 01-19-2010, 08:37 AM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
Use a flanger to step the fender side of the repair.Use panel weld adhesive rather than flux welder just use drill screws to hold it all together till the glue dries then remove the screws and fill the screw holes with more glue.Install the fender and make adjustments before glueing it all together,or you'll never get back apart,the glue joint is stronger than the metal.The metal will tear before the glue lets loose.So get it all screwed together before glueing.JB weld works well too...(no gun)
