The red stuff is likely to be Nitro-Stan, a lacquer based spot putty. Easy to work with, worked great for the right applications, but there are better products for the modern supplies. Take it off.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain |
looks like you cut thru the brace near the fold over flange, and I bet it's rusted as well. Did it cut thru where you noticed it cutting a little too easy? If so it's rust.
To be thorough you'd have to buy a patch for the brace and a patch panel for that area and wrap it around the support. It should already be bent in that area. If there's nothing considerable to line up line it up at the bend and then scribe/cut/ etc. If you want the easier route just clean up the cut and make a patch but weld up that brace where you cut thru first. If you want to learn how to make patch panels check this out. It's in there somewhere. http://www.youtube.com/watch?v=cgykAgpSyR4 here's one I did with the brace
Thanks for the suggestions. No problem making the patch, and thanks for the vid link. I think I am going to cut out as much as I can on the brace and patch in a section. I will probably have to leave the lower section of the brace where it pinched to the fender. I have read and read the rust wiki and we all know that to get rid of rust you have to cut it out.
Also thanks for giving me some insight on the body filler stuff, I was told to leave body filler but obviously do not want it to mess up the paint. |
| Suggestions on extending a fender? | 39chevy | Body - Exterior | 3 | 04-07-2008 07:41 PM |
| Cycle fender bracket suggestions | cboy | General Rodding Tech | 5 | 10-21-2007 08:46 AM |
| fender lip rust repair | blackjackbender | Body - Exterior | 10 | 03-24-2006 12:04 PM |
| Rust Spot In Back Fender Help | 67camarokid | Body - Exterior | 5 | 01-16-2006 08:17 AM |
| Fender rust | magic781 | Body - Exterior | 1 | 05-11-2005 08:50 AM |
