Fender well reinforcing - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2002, 03:48 PM
Question Fender well reinforcing
Anyone used metal rod/tubing to strengthen their fender wells? Looking for info on size/material.
Old 05-04-2002, 04:50 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Post
I have done that a long time ago. I remember I used steel rod. I can't remember what size, I think it was either 5/16 or 3/8. Just weld a little, heat a little bend a little , then weld a little more and keep on doing that till you got the whole thing. Grind it a good and slick and smooth up any rough places with Dyna Glass
Old 05-06-2002, 03:08 PM
F-1Rodder's Avatar
Post
I use 3/8" steel fuel line. It is fairly light and strong. Also works pretty well for re-radiusing fender well openings and replaces drip rails over doors.
Old 05-08-2002, 10:03 AM
Wink
Thanks for the replies, gents. 3/8" is the right size I need, and I like the idea of the tubing for its lightness. Should be much easier to work with also. Now to find someplace that carries it.
Need fender alignment help tcruise Body - Exterior 5 11-14-2005 02:21 PM
Correct sequemce for body panel alignment Ripped Body - Exterior 4 10-19-2005 09:14 AM
I need help with fender patch panels. unstable Body - Exterior 6 03-28-2005 09:27 PM
Part 2--Metalshaping/Panel Replacement '34 Chrysler fender Randy Ferguson Body - Exterior 1 06-03-2004 08:27 PM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 07:50 PM
