fender welting??? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-18-2007, 02:25 PM
I like the self adhesive gasket idea,but never saw it,where can it be bought?
  #17 (permalink)
Old 01-18-2007, 02:36 PM
You might want to search around at auto and truck parts stores for a universal seal/weatherstrip, the stuff is available in different widths and thicknesses and comes on a roll to be cut to lengths. A closed cell foam would be best and won't hold any moisture, you'll want it fairly thin so it compresses.
  #18 (permalink)
Old 01-18-2007, 03:21 PM
OK thanks,I sure don't want something that would hold moisture
  #19 (permalink)
Old 01-18-2007, 05:55 PM
poncho62's Avatar
Wiki Edits: 5
Another problem with not using the welting is, if the edge of the fender is not absolutely perfect, it will really show bad. The bead on the welting will hide these little flaws.....Something to consider.
  #20 (permalink)
Old 01-18-2007, 06:00 PM
Mine are straight as far as I can tell,but they arn't off yet
Need fender alignment help tcruise Body - Exterior 5 11-14-2005 02:21 PM
Correct sequemce for body panel alignment Ripped Body - Exterior 4 10-19-2005 09:14 AM
I need help with fender patch panels. unstable Body - Exterior 6 03-28-2005 09:27 PM
Part 2--Metalshaping/Panel Replacement '34 Chrysler fender Randy Ferguson Body - Exterior 1 06-03-2004 08:27 PM
Fender Welting JhnBrackett Body - Exterior 5 04-21-2004 01:21 PM
