fender welting??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2007, 03:10 PM
fender welting???
I have a 26 T that I will be disassembling to strip it of lacquer paint. What I want to know is can I put the car back together without putting the welting between the body parts?
Thank you Gary
Old 01-17-2007, 04:53 PM
car builder
yes you can
Old 01-17-2007, 05:01 PM
Thank u
I just didn't know if there was any drawbacks to doing it that way ,My car is all metal with fiberglass fenders,should I put anything between the parts,or just bolt them together?
Old 01-17-2007, 05:56 PM
It would seem to be a good idea to replace. I wold think it provides some vibration dampening and wear of two part rubbing together, chipping paint, leading to rust etc. No por, just my opinion. By the way, welting is readily available. Check ebay.
Good luck.
Old 01-17-2007, 06:06 PM
I was thinking about putting thin nylon washers over each bolt,how do u think that would work? I know welting is readily available,I just don't really care for it
Old 01-17-2007, 06:25 PM
poncho62's Avatar
Wiki Edits: 5
Use the welting, if you dont want ut to show, trim the round bit off.....Saves on squeaks and paint rubbing off.
Ontario Rodders
Old 01-17-2007, 08:04 PM
You don't think the nylon washer idea would work then?
Old 01-17-2007, 08:23 PM
poncho62's Avatar
Wiki Edits: 5
You would get water splashing up between the joints.
Ontario Rodders
Old 01-17-2007, 08:31 PM
302 Z28's Avatar
Instead of the thick welting you could use some thin rubber, about 1/32".
Vince
Old 01-17-2007, 08:45 PM
What do u think about a bead of silicone?
Old 01-18-2007, 05:07 AM
302 Z28's Avatar
Could make removal a bit of a chore. Use a bycycle inner tube and cut it to fit.
Vince
Old 01-18-2007, 07:51 AM
That sounds good,maybe I'll try that
Gary
Old 01-18-2007, 11:36 AM
shine's Avatar
Last journal entry: some progress
put the welting in from the back. it will still do it's job but you wont see the welt. may have to trim 1/2 in off.
Old 01-18-2007, 11:59 AM
somethingelse to consider!
thanks!
Old 01-18-2007, 12:18 PM
Or use a urethane seam sealer-this avoids having an open crevice that'll hold moisture but will make removal of the fenders a PITA. Another option would be to apply a self adhesive gasket strip to the body then bolt the fenders on, two sided adhesive tape would also work.
Need fender alignment help tcruise Body - Exterior 5 11-14-2005 01:21 PM
Correct sequemce for body panel alignment Ripped Body - Exterior 4 10-19-2005 08:14 AM
I need help with fender patch panels. unstable Body - Exterior 6 03-28-2005 08:27 PM
Part 2--Metalshaping/Panel Replacement '34 Chrysler fender Randy Ferguson Body - Exterior 1 06-03-2004 07:27 PM
Fender Welting JhnBrackett Body - Exterior 5 04-21-2004 12:21 PM
