Hotrodders Bulletin Board
#1
FENDERWELL HEADERS in a 55 chevy
I have a 55 chevy with a sbc. I use manual brakes, am running a Muncie M21 tranny with the cast bellhousing with the "ears" trans mount, and stock steering. I am interested in the hooker fenderwell headers part #2102 but am concerned of the fit. The motormounts are custom solid mounts and am pretty sure that the engine is set back about 2". I am running edelbrock rpm heads and the passenger side was in contact with the firewall requiring massaging. I also had to modify the firewall to run a HEI distributor. My supplier does not carry these in stock and a return would be impossible if these would not fit.
Please Help me!! Thank you Ted |
#2
hand made headers
ask around and try to find someone that will hand make a set for you this is not as scary as it sounds and the fit will be better
but beware dont get talked into going to big 1'3/4 1'7/8 primarys are surficent for the street and a good shop will press bend them for you or you can cut and shut some mandrell bends your self but youwill need good welding skills |
#3
I looked into having a custom set made but the cost is 900.00 compared to 630.00 Canadian for the Hookers.
![]() The Hookers are 1-3/4x32 primaries with a 3" collector. Here are some more questions! I am running 10.5 to 1 comp, balanced, edelbrock rpm heads, super Victor Jr Intake, 700 cfm holley D.P, Roller rockers, 244/253 duration with 510/533 lift 107/112 lobe sep cam, desktop dyno at approx 460 hp. Do you think that these headers would be compatible? Car weighs 2900 lbs w/o me! 410 gears 30" tires. Should I run 2.5" exhaust or 3". Last edited by Knobie : 10-02-2003 at 08:07 AM. |
#4
If I end up not using the fenderwell headers, does anyone know of a good header that will allow for good ground clearance as the 55 is pretty low?
Thanks Ted |
#5
custom headers
hand mades are made on youre car these
these will give the best fit and if the shop has a four poster hoist it will allso show you the ground clearance threres three or four hundred in the price but if you rip the factory ones on a speed hump you have to throw them away tri y's give better bottom end performance and more ground clearance and if you think about it on the street most of your time is under sixty miles an hour ok we all like to race but 4 into 1's are for prolonged high revs race car nascar stuff dont get me wrong 4into1's will work too but tri ys' may give you better service good luck Ian |
