gas gage
if you have an analog gage, then it works on the principle of magnetism. if you could imagine inside the gage there are two little coils with the gage needle between them. one of those coils is connected to the battery through the ignition switch, and ground on the other end, so it is a constant electromagnet. the other coil is connected to the battery in the same way as the first, except for a ground it goes to the rheostat in the sending unit-in tank- which gives a variable amount of ground depending on how much fuel is sensed. more fuel gives more ground which gives that second little coil more magnetism, which pulls the gage needle closer to the full mark. less ground in the sending unit would let the first coil overpower the second coils magnetism and the gage needle would go closer to empty. if your gage is reading funny as you rev up the car, then you are probably experiencing a voltage fluctuation, which causes a fluctuationin how much magnetism those little coils are putting out. try putting a volt meter across the battery and rev the engine up some. see how much the voltge changes. was your vehicle originally a 12v system or was it converted? sometimes the converted vehicles will have a resistor to drop the votage for gages etc. a voltage fluctuation may cause a bigger fluctuation when dropped through the resistor. also check for a bad ground in the dash cluster ground.
have fun and keep us posted
dsraven
