Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - A few changes to 540 hp carcraft buildup... what kind of hp loss? guesstimates please
Old 07-28-2003, 09:07 PM
Super Streeter Super Streeter is offline
First off,a real 540 hp is a tall order out of a 383 or even 406 on the street.Westech's dyno is a bit optimistic,so figure that you are looking at that engine being a real world 500 hp combo.The combo of a small carb and dual plane is a disaster.The split plenum of the dual plane needs more carb then a single plane,a lot more.In reality,that engine combo needs to spin 6500 rpm of even a bit more to make an honest 500 hp.I would want at least 800 cfm on that combo,even maybe a 950 hp carb.that combo should work best with at least 4000 stall and 4.56 or more gears.It isnt a very streetable combo for everyday use.I would run it with a gasket matched Victor JR or Strip Dominator,and an out of the box 850 double pumper with the correct jetting.I would also run at least 1 3/4 primary pipes and 3" exhaust.Good luck.
