a few electric fuel pump questions: - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2012, 05:23 PM
Banned User
1) If you are installing an electric fuel pump in a chassis that originally just had an engine mounted mechanical pump----where the fuel lines run into the top of the fuel tank----this means that the electric pump is not gravity fed for a few inches but it is still pretty close to the tank. Is this generally ok and not a problem?
2) In cases where you are still using the stock mechanical pump but also using an electric pump (say for racing) and sometimes you don't use the electric pump---like driving on the street, is this ok for the electric pump? How does this work----does the electric pump just "freewheel" when not turned on? Like if you put a fan outside on a windy day but did not turn it on, i would imagine that the fan would still turn. Would this be harmful to the elec pump?
Old 07-28-2012, 07:19 PM
Banned User
But how does it work when the pump is not turned on? Would this be a restriction in the line somehow?
a) What about TBI to carb conversions? Can we leave the stock electric pump in the tank?
Electric fuel pump, fan and water pump Curtis Thornton Electrical 9 05-08-2011 02:41 PM
Electric fuel pump 68ss Engine 9 10-29-2008 03:12 PM
Electric fuel pump to manual pump engine.. RookieRodder Hotrodding Basics 7 02-14-2008 06:28 PM
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 04:17 PM
Electric fuel pump gto401 Electrical 2 07-05-2004 08:00 AM
