Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - A few ideas on manifold vacuum advance?
Old 10-21-2012, 09:20 PM
Greg T's Avatar
Greg T Greg T is offline
www.krusinklassics.net
The only difference between ported vac and manifold vac is that ported is a signal pulled from above the throttle plates and manifold vac comes from below the throttle plates. Ported is (or should be) 0 at idle and increase with tip-in, whereas full manifold vac is highest at idle and deceleration.
The Following User Says Thank You to Greg T For This Useful Post:
chevy302builder18 (10-22-2012)
