few more 700r4 rebuild questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2012, 05:47 PM
#1 - I want to replace the larger spring in the servo assy(master kit came with the smaller spring) but dont see one with similar measurements at transmissioncenter.net or transmissionpartsusa.com . Mine is orange and measures .98" high, 1.2" diameter, coil thickness .08" Does anyone know where to find these?
#2 - Where does the .38" steel cap plug go(it was in the master kit)? My rebuild video doesnt mention it and google searches turned up nothing.
thanks for any help guys!!!
Old 09-04-2012, 10:05 PM
joshp83's Avatar
owner of Prices Garage
the servo has 2or 3 springs on it and one between it and the case dacco kits comes with the small one to repace the outter a vette has 2 inner springs
that plug is for the 1982 that had a pin to drive out for the park pawl
Old 09-05-2012, 05:28 PM
Thanks! That plug thing is crazy, Alto needs to get that out of the "87-93" kit! The servo spring in their kit is the small one located at the washer/C-clip. The one I want to replace is the "servo return" spring. It's the larger one on the shaft that could fall off when removing the servo assy from the case.
700r4 after rebuild mafiacustomz Transmission - Rearend 9 06-12-2012 01:44 PM
700R4 Rebuild PA-12 Transmission - Rearend 2 04-25-2010 04:35 PM
700R4 Rebuild Parts and Advise Questions wild_man84 Transmission - Rearend 37 04-09-2010 05:07 PM
700r4 Rebuild Questions 123pugsy Transmission - Rearend 9 12-03-2007 04:36 AM
700R4 Rebuild StudebakerBob Transmission - Rearend 21 11-09-2004 10:04 PM
