A few paint pics - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2010, 11:31 AM
Ripped's Avatar
Last journal entry: First RoadCourse Video
A few paint pics
I thought that I would share a few pics, as I learned 99% of what I knew about bodywork, from reading and asking questions on this forum.
Just a little on the car. I did a lot of fiberglass work, fitting and gapping all the panels, block sanding the raw mat on the underside of the glass hood and trunk, to nearly the same as the outside of the chassis. Block sanded inside of the scoops (not shown) The trunk is extensively modified. Besides gapping and matching the shape of the body (These things fit notoriously badly) After sharpening the roof lines, I tried to carry the sharpness of the lines down onto the trunk shoulders. The trunk extensions were also matched to the shape of the trunk, and I raised the spoiler 1", gave it more of a radius.
I stretched the rear quarters 1 1/8" mini-tubbed 1 1/8" Spent a lot of time with the shrinking disk on the 1/4's and roof. Spent lots of time on body lines and gaps
So now with the first bit of paint on the car, the 2 years of bodywork and block sanding, don't seem to have been as evil as I remember.
There is a little more work to be done at the paint/body shop. All the clear get's wetsanded and redone. Then the paint will be all finished.
I got complimented again, on my bodywork, by the painter, so that was kind of rewarding, as it is seeing it finally get some colour after all these years
ID:	48559   Click image for larger version
ID:	48560   Click image for larger version
ID:	48561   Click image for larger version
ID:	48562   Click image for larger version
Old 10-01-2010, 09:31 PM
001mustang's Avatar
wow.
only problem i see...too much tread on the tires... easy enough to burn it off.
panel fit on 67 not easy if using repro panels.
Old 10-01-2010, 11:59 PM
Ripped's Avatar
Originally Posted by 001mustang
wow.
Thanks
Yeah definitely too much tread. i'm gonna have to get those clear overlays for the rear quarters, though now that it's painted.
Panel fit... is a long bad nightmarish story. 1st bodyshop which was assigned to the car when I bought it, outright lied. 2nd bodyshop, which I hired to do the welding panel instalation, put a lot of it together wrong, and cost me a lot of money. I had 2 years of solid metalwork, fiberglass and blocking to fix it all up.
It's too bad. In retrospect, i could have done a better job myself, purchased a really good tig and mig welder, and have been miles ahead
Old 10-02-2010, 03:32 PM
That thing looks incredible
Are those the 18x10" wheels? Did you get them widened? Tire size?
I want to build one of those one day. Could you explain what you mean by "sharpening" the lines? Im a rookie.
Old 10-02-2010, 05:24 PM
302 Z28's Avatar
Awesome, you should be very proud.
Vince
Old 10-02-2010, 05:28 PM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Yes, very proud.
Old 10-02-2010, 06:06 PM
chas350's Avatar
Nice work!
Old 10-02-2010, 08:30 PM
001mustang's Avatar
curious why hood is resting in forward position?
Old 10-03-2010, 12:29 AM
Ripped's Avatar
Thanks guys
Sharpening the body lines (I believe I learned from posts here)
(after metal work)
For me was using a cheap laser to illuminate the body line, if it was straight.
Place several layers of tape against the line.
Use a thin layer of body filler to the tape
Block sand
Remove the tape
Use a different colour hardener
Bodyfiller on the other side of the line
Block sand to the line (not over)
Curved lines, were laid out by eye.
The process is repeated over and over again in some cases, until satisfied with the result.
Using two colours of hardener will make it easy to see the body line when sanding
Leave the line sharp, by not sanding the edge/intersection of the two planes, because the paint when it goes on, will round the lines, due to it's thickness.
An example of that on my car, is there are two lines that come off the roof going from the A pillar to the C pillar through the trunk. Stock they are washed out on the metal, and not seen on the f/g trunk. If you look at the trunk pics you will see 2 lines 1" apart that come off the C pillar though the fiberglass trunk.
Most people will never notice this. I think it was kind of cool, and looks better. It took a long time though.
Rear Wheels are 17 x 10.5 and tires are 315/35/17
Hood is resting actually where it belongs. It looks like it is in the forward position, because it is missing the part in the picture below;
ID:	48581   Click image for larger version
ID:	48582   Click image for larger version
Old 10-03-2010, 01:12 PM
mitmaks's Avatar
Last journal entry: Grille
Nice looking Mustang. Hard work pays off
Old 10-04-2010, 06:18 PM
001mustang's Avatar
Plz post a pic when all done.
Such a nice ride.
Old 10-06-2010, 12:46 PM
cyclopsblown34's Avatar
Colorsanding painter
WOW!
Old 10-06-2010, 01:30 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
Looks gorgeous. Can't go wrong with a mustang anyways as far as I'm concerned
Old 10-20-2010, 10:11 AM
Ripped's Avatar
As requested a few pics. I worked pretty hard getting the pieces back on, so I could take it for a short drive last night. Overall I am pretty happy. There is one small clear run, that I'll get them to fix, and I need to do a bit more fitment on one of the rear spoiler extensions. Not a big deal. I'll take it off when the snow comes.
ID:	49058   Click image for larger version
ID:	49059   Click image for larger version
ID:	49060   Click image for larger version
Old 10-20-2010, 10:28 AM
I like the wheels. Good looking body work and paint.
Questions for paint guys - body show messed up my car zbhover Body - Exterior 9 06-25-2009 07:58 PM
Paint question for the experts Kevin45 Body - Exterior 34 02-23-2009 05:03 PM
what color to paint? jum Body - Exterior 14 07-30-2006 12:29 PM
Paint is done on my GMC (PICS) dubie Body - Exterior 1 07-03-2004 10:50 AM
